Câblage sur moteur XU9J2  Pop10
Le forum aux 205961 messages!
Cartes Pokémon 151 : où trouver le ...
    Recherche
    Recherche
    Masculin D'où viens-tu ? : HR / D
    Ma 405 est une : SRI
    Câblage sur moteur XU9J2  Empty Câblage sur moteur XU9J2
    Message par Recherche Mer 11 Jan 2017 - 22:25
    démarreur échange. J'ai oublié ordre les quatre vert fiche. frown
    Schéma de câblage?
    Peugeot 405 I (15B) 1.9 88kW 120PS (1988-1992)
    Câblage sur moteur XU9J2  Cable10
    Hello,
    we changed the starter because the old one is broken. But we forgot the order of these four green plugs. I don't know in wich order I have to plug them in. I have tried it but the motor won't start. Maybe something is broken. But to find the problem the four plugs have to be in the right order.
    Do you have a wiring diagram?
    [EDIT ADMIN] : I changed your title as said below.
    Câblage sur moteur XU9J2  Empty Re: Câblage sur moteur XU9J2
    Message par Hulst Jeu 12 Jan 2017 - 18:55
    Hello,
    Just for my comprehension, what are the green plugs? The spark plugs or injection parts?
    I remember that the ignition order on a 4-cylinder engine is 1-3-4-2, perhaps it can help you.
    I change your title in order to make it easier to understand cligne
    Recherche
    Recherche
    Message par Recherche Jeu 12 Jan 2017 - 22:00
    Hello,
    thank you for the numbers. Tomorrow we will try it.
    I don't know what it is. My cousin helps me because I don't know much about car engines. But I think they are the injection parts. Under the yellow plugs above are the spark plugs.
    We forgot the order of these plugs because the engine has been disassembled for more than three months. The starter was broken and it's not possible to get a starter in germany for less than 100€. I have searched everywhere. There are only 50 Peugeot 405 I with 120PS engine in germany. Total about 2000 Peugeot 405 in germany.
    I got my starter in croatia from a scrap yard. But now we forgot the order of these plugs. Embarassé
    Message par NanjaT Ven 13 Jan 2017 - 1:40
    These are the power wires of the injectors. There is no numbers on it ?
    Recherche
    Recherche
    Message par Recherche Sam 14 Jan 2017 - 16:29
    There are the numbers 1, 2, 3 and 4 on it.
    I hope we have got the problem. A part of the distributor (le Delco) is broken. I am going to buy a new one and try it again with the order of these plugs.
    I will tell you the right order if my car starts again. I hope it will start because this is my first car and i like it very much.
    Câblage sur moteur XU9J2  Imag3510
    Câblage sur moteur XU9J2  Imag3511
    Câblage sur moteur XU9J2  Imag3512
    Message par NanjaT Dim 15 Jan 2017 - 19:36
    Just plug according numbers on wires. I think your problem is tais broken rotor
    Recherche
    Recherche
    Message par Recherche Mar 24 Jan 2017 - 20:33
    Yes, the problem was the broken rotor. But the first problem was the broken starter. I have checked it and it's really broken.
    Two problems, but now my car is working.
    The order of this green plugs is:
    4 - 3 - 2 - 1
    When you stay in front of the motor and the battery is right.
    Thank you all for your help.
      La date/heure actuelle est Sam 27 Avr 2024 - 3:30
